Activity Forums Apple Final Cut Pro Legacy Capture DV-CAM Progressive
  • Capture DV-CAM Progressive
    Posted by Roi Turnoy on October 8, 2010 at 6:52 am
    Hi
    I need to Capture DV-CAM Progressive
    What do I need to figure in the Log and Capture window to capture it correctly?
    I’m capturing with Sony DSR-11 Via Firewire.
    thanks
    Roi
    Rafael Amador replied 15 years, 11 months ago 3 Members · 7 Replies
  • 7 Replies
  • Michael Gissing
    October 8, 2010 at 6:55 am
    DVCam is interlaced. Even if you shot in a progressive mode, the data is in an interlaced frame. This is sometimes called psf.
    Capture as interlaced. If the footage is psf then you can set the field dominance to none in your sequence settings.
  • Roi Turnoy
    October 8, 2010 at 7:03 am
    Hi
    So I need to set it as DV-PAL 48KHZ or DV-PAL50 48KHZ?
    Roi
  • Michael Gissing
    October 8, 2010 at 7:21 am
    DVCam uses the standard DV codec so capture with that setting.
  • Roi Turnoy
    October 8, 2010 at 7:23 am
    Just to be sure –
    DV-PAL 48 KHZ?
  • Michael Gissing
    October 8, 2010 at 8:17 am
    Yep DV PAl 48khz.( DV-50 is a Panasonic codec for the DVCPro 50 cameras)
  • Roi Turnoy
    October 8, 2010 at 8:30 am
    Thank you very much!!
  • Rafael Amador
    October 8, 2010 at 1:35 pm
    After capture, don’t forget to check the clips as field order “NONE’ (Progressive) in the Browser.
    Rafael
    http://www.nagavideo.com
