Activity › Forums › Apple Final Cut Pro Legacy › capture disruption
  • capture disruption
    Posted by R.l. Mcmurray on July 8, 2005 at 9:13 pm
    When I capture in FCP, I get a message that says “capture has reached the end of the tape” but there is still plenty of tape. The problem didn’t arise until I started using a 2nd Lacie external firewire drive. (The 2nd drive is daisychained through original.) It’s odd to me that the 2nd external could be causing a problem during capture because I only use it to store Render files. Any thoughts?
    yes I looked in the manual,
    R.L. McMurray
    Jerry Hofmann replied 21 years, 2 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    July 8, 2005 at 10:18 pm
    Log the material past this point and see if you can’t capture it… if you still can’t I’d suspect the source machine or the tape itself… i.e. this isn’t a software problem don’t think.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
