Activity › Forums › Adobe Premiere Pro › capture denied
  • capture denied
    Posted by Rob Kahn on October 17, 2006 at 4:15 pm
    All of a sudden Premier Pro (1.5 and 2.0) stopped recognizing my camera. My camera is listed in the capture devices. Ive tried two machines different cables and even a different camera but no luck. Other devices work in the firewire plug. I’ve tuned off antivirus, however it seems something is still blocking the connection. It used to work but not now. Any Ideas?
    HP xw6200 dual xeon Sony pvc 120bt
    Rob
    Blast1 replied 19 years, 11 months ago 3 Members · 5 Replies
  • Vince Becquiot
    October 17, 2006 at 4:28 pm
    If you have confirmed that the cable and camera indeed are working properly:
    -Unplug all other firewire devices, restart, and plug the camera by itself.
    -If you have system restore enabled, you could try going back and see if that solves it.
    -If that doesn’t do it, I’d go for a clean install of Premiere and /or your OS.
    Cheers,
    Vince
  • Rob Kahn
    October 17, 2006 at 5:38 pm
    what I expected. but was hoping not to have to.
    Rob
  • Blast1
    October 18, 2006 at 6:17 am
    [robkahn] ” My camera is listed in the capture devices.”
    Where is the “Capture Device” listing? It should be listed as a “imaging device” in the Device Manager or under “scanners and cameras” in My Computer, if its being listed as a “capture device” that maybe your problem.
  • Rob Kahn
    October 18, 2006 at 1:03 pm
    Its not being listed at all
    rob
  • Blast1
    October 18, 2006 at 8:07 pm
    If its not being listed in the two locations I mentioned you have other problems than Ppro, do you have another device/s connected to your firewire port? if so disconnect all other firewire devices, reboot and try again, like Vincent mentioned check your cables and connections, most camcorders do not have switchable unique address, if there are two such devices on a port only one will be selected.
