Activity Forums Apple Final Cut Pro Legacy capture clip issue
  • capture clip issue
    Posted by Quaadnyc on October 26, 2005 at 1:04 pm
    fcp 5, g5 dual 2Ghz lotsa ram, xraid 1Tb
    when capturing a logged clip of 23 min, capture stops at 22 min. dialog box returns asking if i want to capture the clip.
    the 22 min clip is captured, shows up in bin. we arrived at a workaround which is to log clip as 24 min and then we get the 23 we need.
    has anyone experienced this bug? we have 4 fcp stations, all nearly identical. none of the other 3 have this problem. never heard of it before.
    not a timecode break, we can capture the last minute on its own if we want with now prob. several tapes, same problem.
    Quaadnyc replied 20 years, 10 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    October 26, 2005 at 3:35 pm
    If it’s only showing up on one station, I’d venture a guess that this station needs it’s software reinstalled.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Quaadnyc
    November 1, 2005 at 3:30 pm
    If anyone is still interested, the problem turned out to be linked to capture settings. It was set to capture 4 tracks of audio, but there were only 2 tracks on the tape. I’m not sure why, but when we turned off 3&4 the problem went away.
