Activity Forums Apple Final Cut Pro Legacy Capture Cards
  • Posted by Yari Wolinsky on October 18, 2006 at 7:05 pm
    I am in the process of upgrading to a new editing system and have been wondering about investing in a capture card. I am a bit confused about the exact use of this hardware though. Can someone explain the benefits of using one in a Final Cut system?
    Yari Wolinsky
    Enzo Tedeschi replied 19 years, 10 months ago 2 Members · 1 Reply
  • Enzo Tedeschi
    October 18, 2006 at 10:32 pm
    If you have a need to ingest footage from a source other than DV or at a higher quality, you’ll want a capture card. For example, if you wanted to do uncompressed SD for broadcast, you’d want a Blackmagic or Kona card that will give you SDI inputs. Some have degrees of Hardware Acceleration features, but they are principally I/O devices.
    Enzo Tedeschi
    ____________________________
    Editor
    http://www.outpostpps.com
    Sydney, Australia
    Check out our latest music video – http://www.outpostpps.com/thebleed/
    Check out the Outpost PPS Video Podcast launching October 29 – http://www.outpostpps.com/podcast/
