Activity Forums Adobe Premiere Pro Capture card in 4:2:2 color?
  • Capture card in 4:2:2 color?
    Posted by Jason on November 30, 2005 at 7:46 pm
    I am a long time Premiere user and am currently working with PrPro 1.5. I’ve always felt like I’m getting lackluster results from PrPro and I’d like to take a step up in quality. I currently have a Sony DSR500ws camera(25 Mb, DVCAM, 2/3 in. chips) and I firewire my footage in and out of my computer.
    In order to improve the overall quality of my productions, I’ve considered switching to DVCPRO50 for the 4:2:2 color space.
    I’m really not unhappy with my DSR500, I just want to increase the quality of my renders and final outputs. Can I use my DSR500 camera, which records 4:1:1 color, but edit and output in 4:2:2?
    If I buy a decklink card and a DVCAM deck with SDI or component in and out, can I edit in 4:2:2 color space and output at a higher quality? I realize my video footage won’t be any better, but will my graphics?
    Any other suggestions for upgrading quality?
    Thanks in advance,
    Jason
    Mike Smith replied 20 years, 9 months ago 2 Members · 1 Reply
  • Mike Smith
    December 2, 2005 at 10:19 am
    DSR 500 is nice camera for DVCAM / standard definition: I’ve hired crews using it and had very good results.
    You can obviously switch to edit in full broadcast uncompressed standard definition, capturing via an (expensive) dvcam deck with SDI output, or the DSR45 I think has component out. You will need a lot more disc space and a very fast RAID to handle the speed you need for data in and out.
    Your footage will not improve at all. Your colour correction potential will improve only a little. Your chromakeying in PPro will improve, though I much prefer to use Keylight in After Effects to key, and have found it produces excellent results even from DVCAM.
    Unless your final output is to broadcast tape (or film), nobody but you is going to see the difference.
    I have set up to use uncompressed standard def from digitbeta via a decklink card alongside a firewire fast-and-cheap, and have found, to my surprise, that the differences in final output to tape or DVD are very, very difficult to spot.
    BTW, the Decklink card I find very good, even if the Windows drivers are still evolving very rapdily and perhaps have a little way to go – e.g. as of yet your only editiable windows capture is in uncompressed or DV. On the Mac, Decklink will reportedly capture offering a range of Quicktime codecs.
    I suspect that PPro is not to blame for your feeling of lacklustre quality, and probably nor is the DV codec. Interesting stories well told, striking photography, action, composition, lighting, great audio, editing … Does the DSR500ws not let you play with the image set-up to produce different looks …?
    Hope it all works out.
