Activity › Forums › Apple Final Cut Pro Legacy › Capture card (HD) for Xbox 360
Posted by Brian Baldomero on November 24, 2009 at 8:29 pmI don’t exactly know where to put this, but since I work with Final Cut I chose to put it here.
I’d like to capture some footage of me playing Xbox360 but the only things I’ve found was capturing stuff in Standard. I do like to play the games in full HD so I don’t want to hit the switch on the back of the XBOX to play in standard. I currently work on a MacBookPro. How do I capture myself playing in full HD?
Mario Rubertis replied 16 years, 10 months ago 8 Members · 14 Replies -
Richard Sanchez
November 24, 2009 at 9:13 pmYou’d need the AJA IOHD or the Matrox MXO2 to capture via HDMI.
Richard Sanchez
North Hollywood, CA“We are the facilitators of our own creative evolution.” – Bill Hicks
John Fishback
November 24, 2009 at 9:33 pmOr a converter like the AJA HA5 that converts HDMI to HD-SDI, and then use that with your capture card.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Brian Baldomero
November 24, 2009 at 10:28 pmI forgot to add. I am connected thru component. Is their a way to do it thru component?
John Fishback
November 24, 2009 at 10:42 pmCheckout the other AJA mini-converters. There’s probably one to go from component to HS-SDI.
John
Atticus Culver-rease
November 25, 2009 at 12:35 amI’ve done this before, and I had to capture via component because the HDMI output has HDCP. I know the AJA IO doesn’t support HDCP, not sure about other options like the Matrox stuff. When I did it I went component into a Folsom ImagePro HD scan converter and spit out HD-SDI to capture into my system through a Kona 3. Depending on your setup you may be able to go in component directly or use a cheaper converter, but I had the ImagePro handy and knew it would work. The other thing is that the audio output is unbalanced so I had to convert that to feed it to the Kona as well.
You said you’re on a Macbook Pro, what sort of capture device are you using?
Andrew Kimery
November 25, 2009 at 2:10 amCapturing via HDMI can be problematic because of the HDCP encryption. You can buy boxes that say they’ll spoof the HDCP but those are spotty as well. We do a ton of gameplay capture and it’s all done via component.
-Andrew
3.2GHz 8-core, FCP 6.0.4, 10.5.5
Blackmagic Multibridge Eclipse (6.8.1) -
Gary Adcock
November 25, 2009 at 3:15 pm[Richard Sanchez] “You’d need the AJA IOHD or the Matrox MXO2 to capture via HDMI. “
Nope.
Since Xbox materials have copyrights the HDCP requirements on the HDMI will prohibit capture digitally.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows for the Digitally Inclined
Chicago, ILhttps://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
Gary Adcock
November 25, 2009 at 3:29 pm[Atticus Culver-Rease] ” I know the AJA IO doesn’t support HDCP, “
Got that backwards- ALL Aja products DO support HDCP digital rights management over HDMI.
gary adcock
Studio37
Richard Sanchez
November 25, 2009 at 6:42 pmI was afraid there’d be a gotcha like that!
Richard Sanchez
November 25, 2009 at 11:15 pmHmm, well I never actually tried it, but the IO HD because the manual says, “HDCP is not supported on either input or output.” Is that incorrect?
