Activity › Forums › Apple Final Cut Pro Legacy › Capture Bin with external Drive
  • Capture Bin with external Drive
    Posted by Chris1234 on July 19, 2006 at 9:55 pm
    Hey,
    Using FCP 5.1 on Macbook Pro. When capturing (FW from Panasonic AJSD255) using the Mac HD as scratch drive (only for a test) system works great.
    As soon as I move the capture scratch to an external FW drive, I can still capture, but the video files do not appear in the bin. I have to import them into the bin after I have captured. Did I miss a setting somewhere to redirect the capture bin to an external drive?
    13 replied 20 years, 2 months ago 2 Members · 5 Replies
  • 13 Create COW Profile Image
    13
    July 19, 2006 at 11:10 pm
    Did you just move the bin folder or have you changed the capture bin target in FCP
  • Chris1234
    July 20, 2006 at 12:17 am
    How do I change the bin target?
    13
    July 20, 2006 at 12:42 am
    In the Top menu click on Final Cut Pro then system setings to set your scratch disc
    I recomend you create a new folder on whatever drive you want to work off of for each different project and change your scratch disk when ever you work on a different project. that way all your captures video render files, autosave files for one project are all located in one place,
  • Chris1234
    July 20, 2006 at 2:55 pm
    Tried that. I changed ALL the settings to the FW drive in a “Final Cut Pro Documents” Folder and they still don’t show up.
    Any other ideas?
    13
    July 20, 2006 at 3:16 pm
    Once you set them to the new location it will only put any newley captured video there
