Activity Forums Adobe Premiere Pro Capture artifacts?
  • Capture artifacts?
    Posted by Luke Swain on September 12, 2007 at 4:58 am
    Every time I’ve opened up Premiere to capture footage in it, there are at least 3 distinct areas in the capture window that give blocky artifacting junk. Sony Vegas doesn’t show this when capturing, just Premiere. It’s as if the codec is corrupt? Don’t even know if that’s possible. I’m using a Canon GL2 as the deck and there’s nothing in the viewfinder that shows such artifacting.
    What gives?
    Perry Cheng replied 19 years ago 3 Members · 4 Replies
  • Mike Velte
    September 12, 2007 at 10:41 am
    Are the artifacts also visible in the video after it is captured?
  • Perry Cheng
    September 14, 2007 at 6:58 pm
    Mike,
    Some people raise this question about CS3 capture artifacts. I thought HDV capture is the same as DV oen and it is just a “tranfer process”, so it it really does not matter what software you use, the end results is the same. Am I off on this?
    Perry
  • Mike Velte
    September 16, 2007 at 10:03 am
    My limited experience with capturing HDV is that it is not data transfer, but a conversion process. The captured file is not ready as soon as the tape ends, depending on the computers speed, the conversion continues for some time.
  • Perry Cheng
    September 23, 2007 at 12:14 am
    I don’t think so. The capture file is pretty much ready as soon as the tape ends, at least for me. I can play it immediately. I don’t think capturing with Premier vs others make a difference. I could be wrong. I wish someone can verify.
    Thanks Mike.
    Perry
