Activity Forums Panasonic Cameras Capture and Crop?
  • Capture and Crop?
    Posted by David Komer on December 24, 2008 at 1:43 pm
    I shot some 25P letterboxed footage on a DVX100A, and have a couple questions…
    1) When I captured the footage through iMovie (as a convenience. I’m going to edit on PC- so I let the Mac work as a capture tool for a moment and I don’t have final cut on it) and then opened the DV clips with MediaTool, it tells me that the footage is interlaced. Why is that? Should I have toggled some other setting or used some other capture tool? I could use Premiere CS3 on the PC if it helps, but I like iMovie for quick captures like this where timecode isn’t important.
    2) What are the exact heights and y-coordinates of the black bars, or in other words- what is the height and starting point of the relevant area on the 720×576 letterboxed image? I could eyeball it, but it would be great to know the official answer 🙂
    Thanks in advance,
    David
    David Komer replied 17 years, 8 months ago 1 Member · 1 Reply
  • David Komer
    December 26, 2008 at 9:31 am
    Ah, seems like question 1 was answered at-
    https://forums.creativecow.net/thread/8/917816
    Though I’m still a little confused on, if I wanted to use the clip properly in premiere. I’ve set up a 25P project- i.e. same settings as PAL DV but no field ordering. The footage looks fine, but it needs to render. Seems like this is more of a compression question so I’ll move it over to there…
    For question 2, I understand that the useable image should be 768×432 (sq. pixels. 720×432 PAL-shaped), which leaves room of 144 pixels for the black bars. In virtualdub, I’m seeing that 69 off the top and 75 off the bottom looks right.
