Activity Forums Apple Final Cut Pro Legacy Capture Across Timecode break
  • Capture Across Timecode break
    Posted by Dan Marlow on June 26, 2008 at 12:47 pm
    Is the incredibly long frame by frame attempt to cross a TC break simply a facet of FCP 6(updated to current revision) or are there any settings that i should be checking. It is occuring with all tape formats via RS422 as well as FW on an 8 core mac pro with a Blackmagic Eclipse attached via PCI card.I’ll leave a tape digitizing and when i come back it will have spent ten minutes trying to locate the TC break.
    Paul Dickin replied 18 years, 2 months ago 3 Members · 5 Replies
  • Herb Sevush
    June 26, 2008 at 2:42 pm
    Dan –
    Final Cut has always been atrocious at handling timecode breaks. Apparently the problem has something to do with Quicktime itself and the way it handles, or more aptly, doesn’t handle timecode metadata. There is currently no solution to this problem, and there won’t be until Apple revises Quicktime in a fundamental way.
    Herb Sevush
    Zebra Productions
  • Dan Marlow
    June 26, 2008 at 2:50 pm
    Thanks for the reply. That is what i suspected and wanted to clarify before i spend anymore time trying to make it behave.
  • Paul Dickin
    June 26, 2008 at 8:46 pm
    [Herb Sevush] “here is currently no solution to this problem..”
    Hi
    Sort of. 😉
    For formats that can be captured by FireWire there is this:
    https://www.squarebox.co.uk/lcplus.html
    Automatic retry if dropped frames or tape errors are detected, ensuring frame perfect captures every time (even when capturing to a slow external drive).
    Automatic handling of timecode resets.
  • Herb Sevush
    June 26, 2008 at 8:58 pm
    Paul –
    When I said there are no solutions to the time code problem I meant within FCP. Still I haven’t heard of this software before, looks like a good deal. Have you tried it and does it properly handle capturing quicktime files across time code breaks? And if it does, then you’ve got to wonder why apple can’t seem to do it.
    Herb Sevush
    Zebra Productions
  • Paul Dickin
    June 26, 2008 at 9:06 pm
    Hi
    I haven’t used it, but I know one of the developers on the team so can get a fully description of its capabilities – and limitations if any…
    [Herb Sevush] “you’ve got to wonder why apple can’t seem to do it.”
    They seem to have applied a Log & Transfer non-linear paradigm to Log & Capture capturing off-tape.
    Seems obvious – even Apple should have thought it through by now…
