Activity Forums Apple Final Cut Pro Legacy capture aborts at shot change
  • capture aborts at shot change
    Posted by Chuckfaz on February 21, 2007 at 8:07 pm
    I’ve looked all over for the ‘button’….
    The capture will stop at shot changes coming from my DSR500ws. I can’t seem to find the preference that turns that great feature off.
    Best,
    Chuck
    Charles Fazio
    Managing Partner
    Mark Rivera’s NewYork State of Mind Entertainment Group (NYSOM-EG)
    Entertainment
    Ben Insler replied 19 years, 7 months ago 2 Members · 1 Reply
  • Ben Insler
    February 21, 2007 at 9:56 pm
    The setting is “On Timecode break” (on the right side of your preferences window). Change the selected setting from “abort” to “make new clip” or “warn after capture”. Make New Clip will break your logged section into multiple logged clips (but be careful, you loose your set pre/post roll time at the beginning and end of each new clip). Warn After Capture allows FCP to ignore the time code break and maintain your logged in and out points – FCP will give you a warning at the bottom of your capture selection window that TC breaks were found once your capture is finished.
    Should do the trick.
    -Ben
