Activity › Forums › Apple Final Cut Pro Legacy › capture 8-bit uncompressed sd prob
Posted by Cade Muhlig on March 5, 2007 at 9:43 pmi forgot what settings to use to capture sd 8-bit uncompressed. i use an hdv tape deck and a kona lhe card. can someone point me?
thanksCade Muhlig replied 19 years, 6 months ago 2 Members · 13 Replies -
Shane Ross
March 5, 2007 at 9:51 pm -
Cade Muhlig
March 5, 2007 at 10:58 pmya, i got that far, but it tells me
“capture preset must have a video or audio digitalizer set to capture. Please change to desired preset in the Audio/Video settings”i captured uncompressed not long ago, but now it gives me this?
Shane Ross
March 5, 2007 at 11:07 pmHave you set the appropriate settings in the AJA Control Panel first?
Shane
Littlefrog Post
http://www.lfhd.net -
Cade Muhlig
March 5, 2007 at 11:17 pmi believe so. theres not much to configure. basically just inputs right?
Shane Ross
March 5, 2007 at 11:20 pmYes…set them for either component or SDI, and what format you will be capturing.
Shane
Littlefrog Post
Cade Muhlig
March 5, 2007 at 11:25 pmi did that, what about the capture/input in the capture settings tab? it is set to generic capture template
Shane Ross
March 5, 2007 at 11:35 pmIn the Summary tab of the AUDIO/VIDEO preferences window, you can change it to AJA Uncompressesed yada yada yada…what I said above. What does that do?
Shane
Littlefrog Post
Cade Muhlig
March 5, 2007 at 11:47 pmsequence preset : uncompressed 8-bit ntsc 48 khz
capture preset : generic cap templ.
device control : non-controllablethose are right arent they?
Shane Ross
March 6, 2007 at 12:08 amNo…not one of those is right.
Sequence Preset: AJA Kona LH-NTSC 8-bit Uncompressed.
Capture Preset: AJA Kona LH-NTSC 8-bit Uncompressed.
Device Control: HDV Firewire.If you cannot control the device via firewire, then you might have to go uncontrolled device. Just know that you will be lacking timecode of any usable kind, so if you lose the media, you are hosed.
Shane
Littlefrog Post
Cade Muhlig
March 6, 2007 at 12:17 ami knew it, theres no option for aja uncompressed. its not there. what did i do to get final cut to not recognized it?
