Activity › Forums › Apple Final Cut Pro Legacy › Capture 16:9 for 4:3 TV
  • Capture 16:9 for 4:3 TV
    Posted by Anne-marie on December 19, 2005 at 3:48 pm
    Hello
    I’m working with FCP 4.5
    I v got a 4:3 monitor, a DSR-1500A (for DV)
    I would like to capture from a DV casette in 16:9
    (we shot with HD camera and tranfered on a mini DV).
    and keep all the 16:9 images in a 4:3 screen
    without streching anything.
    I tried to clic on the litlle anamorphic 16:9 square in the capture preset panel
    of my audio/video setting, but the image still streche
    What do I have to do ?
    Tank’s a lot for help
    L’
    Anne-marie replied 20 years, 9 months ago 4 Members · 5 Replies
  • Todd Beabout
    December 19, 2005 at 3:50 pm
    Your footage is probably anamorphic. You will have to switch your broadcast monitor into 16:9 mode.
    -Todd Beabout
    Vazda Studios
  • Anne-marie
    December 19, 2005 at 4:10 pm
    Tank you for that qick answer Tod
    but I have no setting for that on the TV monitor
    and actually, the clip look streched too in the FCP Canvas
    It become ok when I make it fit for the 4:3 sequence
    with the motion tab .
    Have you an other idea to keep all the 16:9 clip from the cassette
    and put it in a 4:3 sequence ??
    L’
  • Gunleik Groven
    December 19, 2005 at 5:06 pm
    Sounds like the DV-tape is not anamorphic, but letterboxed.
    In that case. you shpuld edit in a standard sequence.
    Gunleik
  • Mark Maness
    December 19, 2005 at 6:37 pm
    Well, if what you are saying is correct, and you’ve digitized all of your footage (sounds like it was dubbed in letterbox) in the 16×9 format and you want to edit in 4×3. Do you want the footage to be full frame or letterbox? If you want it to be full frame, then use these settings below:
    Motion Tab: Distort:
    Upper Left: -480 -240
    Upper Right: 480 -240
    Lower Right: 480 240
    Lower Left: -480 240
    Aspect Ratio: 0
    This will convert all of your 16×9 footage to full frame 4×3. You have tow ways of doing this. One, edit in 16×9 without graphics and create a new timeline that’s 4×3 and drop your 16×9 timeline onto it and use the settings from above. OR, two, you can edit in a 4×3 timeline and drop the motion favorite (the setting from above) onto each and every clip.
    _______________________________
    Wayne Carey
    Schazam Productions
  • Anne-marie
    December 19, 2005 at 7:14 pm
    OK well,
    I feel stupid…
    that’s my mistake !!
    You were right gunleik
    In fact they shoot on HD but the DV tape was transfered on 4:3
    so I don’t need to edit on an 16:9 sequence…
    I just have to do as usual !!
    tank’s
    anyway your imfo will help me in the futur
    ciao
    Anne-Marie
    L’
