Activity › Forums › Apple Final Cut Pro › Captions to Titles
  • Captions to Titles
    Posted by Andreas Kiel on April 16, 2018 at 7:28 pm
    I’ve created a real simple app (time bombed beta) to convert your caption project to one with subtitles.
    The app installs my TextUp Motion Title. This title will be used in the converted project.
    Usage is simple: export XML, in the app set font and font size and drag the XML to the app. Alternatively drag the project from FCP browser to the app window.
    The conversion is really very fast.
    The changed XML will be saved to the desktop with a original project name plus ” subs” name.
    Once the XML is loaded in FCP you “batch set” things like line leading, outline, shadow etc.
    Download the app here:
    https://www.spherico.com/filmtools/TitleExchange/XTCC/XTCC.dmg
    Comments welcome.
    Spherico
    \”He who fights with monsters should be careful lest he thereby
    become a monster. And if thou gaze long into an abyss, the abyss will
    also gaze into thee.\” – Friedrich Nietzsche, Beyond Good and Evil
    Andreas Kiel replied 7 years, 10 months ago 4 Members · 11 Replies
  • 11 Replies
  • Sebastian Leitner
    April 18, 2018 at 4:03 pm
    <3 it!
  • Robin S. kurz
    April 30, 2018 at 5:12 pm
    >5 it!
    – RK
    ____________________________________________________
    Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
    Youtube | Facebook
  • Yosi Ben zvi
    August 9, 2018 at 10:46 am
    Thanks Andreas, Just what I was looking for!
    It does not work for me for whatever reason.
    No matter what I tried for step 2), I got the same error:
    XMLSave: No such file or directory
    Here is a short (lees than 2 mins) video in which I demonstrate the problem.
    https://www.useloom.com/share/786f761b1f2f4a6fa49d4b33d1c7d0d6
    Thanks man!
    Yosi
  • Andreas Kiel
    August 9, 2018 at 4:55 pm
    First make sure you got the latest version.
    Then check the preferences.
    The path for auto-save must exist otherwise set a new one – or deselect all the “auto things”
    Make sure all captions are connected to the primary storyline.
    Spherico
  • Yosi Ben zvi
    August 11, 2018 at 2:19 pm
    Awesome! Thanks for the swift answer – I
    explicitly chose an auto-save folder and tried again – worked! ☺
    Got a warning that not sure what it means, but here it is for the sake of perfecting the cool tool:
    Yosi
  • Yosi Ben zvi
    October 22, 2018 at 5:43 pm
    Hi again, I moved to Mac Pro 15 2018 and after downloading the latest version an making sure all your previous recommendations were set, I made a try to use the Converter – getting this no matter what I try in the settings, automatic or manual:
    An unexpected error occurred in importing the media. (asset: /fcpxml[1]/resources[1]/asset[20])
    Any ideas?
  • Andreas Kiel
    October 22, 2018 at 5:51 pm
    This is a media error – no chance.
    Make a caption only sequence and try again.
    Spherico
  • Yosi Ben zvi
    October 22, 2018 at 6:07 pm
    Hey man, I’m back with a solution for the above error and a workaround for my previously posted warning.
    1. There is an annoying bug in Final Cut Pro X, that even after all processing is done, and all the files are consolidated in the project (I have the “File: copy to library storage location” enabled in preferences, after reopening the ALL DONE project, some files are mysteriously missing, and some elements are still with a dotted line above, as if some processing still needs to be done. And yes, there is the V check, stating that all background processing has been finished.
    Anyway, I had no idea, but 5 files have been somehow “lost” from the project, even though they were in the source files, and I had not moved the originals.
    There was this annoying yellow exclamation mark on the project name, symbolising that something IS missing.
    I tried manually relinking files, but none were missing (according to FCPX)
    However, 5 files were missing, and that’s why I got the
    “An unexpected error occurred in importing the media. (asset: /fcpxml[1]/resources[1]/asset[20])”
    WTF?!? Something is very wrong here but it does not make any sense!
    I had an idea to manually “Consolidate Event Media” (clicl on the project -> File -> Consolidate Event Media),
    and I got errors for 5 different files that were in the source media, but were somehow ,missing from the project.
    Anyway, I dropped the files into the media browser and everything got right.
    That made XCC functional again, as import did not fail now.
    However, I was still getting that annoying warning about “invalid option key was specified”.
    So what I did, is create a compound clip (ALT + G) from al the video files, and tried again.
    This time everything worked like a charm, without errors or warnings.
    Hopes this info is helpful to someone, thanks for the support Andreas!
  • Andreas Kiel
    October 22, 2018 at 6:14 pm
    Thanks & glad you worked out the things.
    Spherico
  • Robin S. kurz
    November 17, 2018 at 6:26 pm
    Can one assume the matter pretty much has taken care of itself with 10.4.4? ????
    – RK
    Youtube | Facebook
