Activity Forums Apple Final Cut Pro Caption in My Timelines don’t disappear
  • James Cude
    October 8, 2013 at 7:20 pm
    Huh- can you explain that a little more clearly?
  • Nicolas Vallejo
    October 8, 2013 at 7:24 pm
    Essentially, I see that in my time line when I should be seeing the footage.
  • James Cude
    October 8, 2013 at 7:32 pm
    Please describe the entire issue clearly- pretend like we’re not sitting in front of your computer with you.
  • Nicolas Vallejo
    October 8, 2013 at 7:35 pm
    Essentially, there’s gaps in how my timeline is showing the clips. It shows the image from the footage in some parts, and in other parts it shows a caption/missing clip, or however you want to call it.
    Here’s another image:
  • Sandeep Sajeev
    October 8, 2013 at 7:39 pm
    There is a little toggle on the bottom right (your right side) where you can adjust the clip height etc. Pick one of the options that shows you the Video filmstrip.
    I’m not in front of a machine at the moment or I would post a screen grab. You can google adjust Clip Height to see which button I’m referring to if you can’t find it.
    Best,
    Sandeep.
  • Sandeep Sajeev
    October 8, 2013 at 7:41 pm
    Ok, I see. Is it only doing this for images? Or are those image sequences that you’ve got there?
  • Nicolas Vallejo
    October 8, 2013 at 7:45 pm
    It’s doing it randomly, only for images. I tried clip height thing and it didn’t work.
  • Sandeep Sajeev
    October 8, 2013 at 8:00 pm
    Close FCP and delete your render files. Then relaunch and it will rebuild your Project thumbnails.
  • Nicolas Vallejo
    October 8, 2013 at 8:12 pm
    That didn’t fix the problem.
  • James Cude
    October 8, 2013 at 8:40 pm
    Are you using Compound Clips- those look like Compound Clips…
