Activity Forums VEGAS Pro Caption Assistant Vasst
  • Caption Assistant Vasst
    Posted by Kelo Kata on May 25, 2011 at 5:16 pm
    Hi!
    Why when installing Caption Assistant disappear GearShift Vasst of Sony Vegas Pro 10 ???
    When I uninstall Caption Assistant appear again GearShift.Is a connection between the two plugins ?
    Is there any video tutorial(training) how to use Caption Assistant ?
    Thanks a lot.
    Kelo Kata replied 15 years, 3 months ago 2 Members · 2 Replies
  • John Rofrano
    May 25, 2011 at 6:37 pm
    [kelo kata] “Why when installing Caption Assistant disappear GearShift Vasst of Sony Vegas Pro 10 ???
    When I uninstall Caption Assistant appear again GearShift.Is a connection between the two plugi”
    There is a physical limit to the number of plug-ins that Vegas will show you. It is possible you have too many scripts which exceeds that limit. Do you have a lot of scripts in your script menu?
    Otherwise there should be no connection. GearShift is a script and Caption Assistant is a Command Extensions. Completely different.
    [kelo kata] “Is there any video tutorial(training) how to use Caption Assistant ?”
    I’m working on it and it will be made available soon. I realize that seeing it in action will help you understand how it can most optimally be used.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Kelo Kata
    May 25, 2011 at 6:48 pm
    Thanks for answer mr.John.It seems like I have some scripts installed,but curiosity was that when installing Caption Assistant disappear GearShift.
    Thanks for future training Caption Assistant mr.John.
