Activity Forums Maxon Cinema 4D Caps on a tracer
  • Caps on a tracer
    Posted by Stephen Moore on October 30, 2018 at 12:55 pm
    Hi there,
    I’ve been following EJ at Eye Desyn on https://vimeo.com/108335058 and have successfully morphed this…
    Into…
    I want to build an animated contour map along the lines of…
    I think I’ve got everything sorted except I can’t put a cap on the tracer when extruded, it’ll extrude as expected but no cap. Does anyone have any ideas?
    Cheers
    Stephen
    Stephen Moore replied 7 years, 10 months ago 2 Members · 6 Replies
  • Brian Jones
    October 30, 2018 at 2:04 pm
    try checking Close Spline in the Tracer – the extrude won’t add a cap on an open spline.
  • Stephen Moore
    October 30, 2018 at 11:20 pm
    Cheers Brian,
    I tried that, sadly nothing doing. A pity, everything else is working just fine except this caps issue.
    Stephen
  • Brian Jones
    October 31, 2018 at 1:37 am
    what’s the tracer’s source, can you post the file?
  • Stephen Moore
    October 31, 2018 at 9:13 am
    Hi Brian,
    Yes, I’d be delighted to. Here’s the link…
    12848_morphtest2.c4d.zip
    I’ve animated the inheritance effector across the tracer. I need to look rather harder at the shape of the contour and how it unfolds from the circle but if you can spot where I’m going wrong with the caps, then I can do that and build a final, stacked topography.
    Many thanks
    Stephen
  • Brian Jones
    October 31, 2018 at 10:41 pm
    I checked Close Spline in the Tracer and it worked
  • Stephen Moore
    November 2, 2018 at 1:13 am
    Hi Brian,
    Thank you, I’m having a ‘I’m feeling dumb moment’. On my original document I had several contours and I was closing the wrong spline. I need more sleep!
    Cheers
    Stephen
