Activity Forums Apple Final Cut Pro Legacy canvas window issue
  • canvas window issue
    Posted by John Paul tansey on June 22, 2005 at 6:15 am
    Ok. there is probably a simple answer to this question but I’m nt sure if I know it. In a current project I am seeing in the canvas window that some clips appear to have a sliver of vertical black on left and right side, while others fit the canvas entirely. The window is set to “Fit All” and the sequence settings are, I believe, correctly set to NTSC 4:3. All AV settings are also set to NTSC. I don’t believe I’ve changed any settings recently so this has me puzzled since it seems like something new (and unwanted). Any suggestions much appreciated. P.s – I find this board most helpful.
    Tripp
    G4 Powermac
    FCP 4.5
    OSX 10.3.9
    2 x External LaCie HDs
    Alan Lacey replied 21 years, 2 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    June 22, 2005 at 12:56 pm
    Are the clips that are showing the black on either side from analog video sources? If so, that’s normal, it’s called blanking… it won’t show up on a TV set because they are out of the safe area. If the delivery is to be something like a web stream though, they will show up, and the common fix is to crop the finished product so they don’t show up.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Alan Lacey
    June 22, 2005 at 4:59 pm
    Even some digi cameras do this too. My JVC GY600. I understand it was designed to work with analogue equipment and produces 704×576 output compared with the 720×576 pal standard.
    Alan
