Activity Forums Apple Motion Canvas settings 16×9
  • Canvas settings 16×9
    Posted by Norman Kolasky on May 14, 2007 at 3:53 am
    I am attempting to create some opening credits with 16×9 screen size to match the format of DV 16×9 from a Sony HDV camera.
    How do I set Motion to have a 16×9 canvas size. Every setting combination that I have tried only produces a regular 4×3 size.
    Can anyone provide some guidance as to how I can get the desired setting?
    Thank you
    Norman Kolasky replied 19 years, 4 months ago 2 Members · 2 Replies
  • Peter Wiggins
    May 14, 2007 at 8:06 pm
    Norman,
    have you tried ‘Correct for aspect ratio’ in the view menu?
    AppleJ brings up the project properties
    Peter
  • Norman Kolasky
    May 16, 2007 at 3:46 am
    Thank you for the lead.
    It was checked. After unchecking, the image outline and contents all
    expanded to the desired 16×9.
    I did not think the solution would be so easy.
    My other conclusion is that the final desired output size format, 4×3 or 16×9, needs to be set when the motion project is exported out of Motion.
    Norman
