Activity Forums Apple Final Cut Pro Legacy canvas resolution
  • canvas resolution
    Posted by Larry Watts on June 2, 2010 at 8:53 pm
    I am editing a 30 min TV program son tandard def 16:9 on FCP. Viewing the timeline on the canvas at 100% looks quite fuzzy. The image sharpens considerably when the player is stopped.
    Is there a resolution setting for the canvas?
    Why such a difference?
    Our other editors on the sam hardware/software do not have such a soft image.
    What possible causes are for this problem?
    Larry
    David Roth weiss replied 16 years, 3 months ago 3 Members · 4 Replies
  • Shane Ross
    June 2, 2010 at 9:38 pm
    [Larry Watts] “Is there a resolution setting for the canvas”
    Nope…
    [Larry Watts] “Why such a difference? “
    #2 Blurry Playback
    Shane’s Stock Answer #2: Blurry/Low Quality playback
    ONLY JUDGE THE QUALITY OF YOUR MATERIAL ON AN EXTERNAL BROADCAST MONITOR, OR AT LEAST A TV.
    The Canvas shows you what happens after the codec you are working with has been applied. The Viewer shows you the material in its native format. Once you drop the footage from the Viewer into the timeline, it inherits the attributes of the sequence. If it is a DV sequence, the footage will render out as DV.
    1. Disable overlays on the Canvas.
    2. Make sure you’ve rendered everything (no green bars at the top of the timeline).
    Video playback requires large amounts of data and many computations. In order to maintain frame rate and be viewable at a normal size, only about one-fourth of the DV data is used in displaying the movie to the screen. However, the DV footage is still at full quality, and is best viewed thru a TV or broadcast monitor routed thru your camera or deck.
    [Larry Watts] “Our other editors on the sam hardware/software do not have such a soft image.”
    SURE about that? RAM? Hard drives the media is on? RT settings all match PRECISELY? Unlimited vs SAFE?
    Shane
  • David Roth weiss
    June 2, 2010 at 9:48 pm
    Well, there is actually a resolution setting in a sense. In the RT settings on the upper left of every FCP sequence, you will find settings for Playback Video Quality, and if the setting selected is “Dynamic” or something less than “High,” one just might discover that their video in the FCP canvas looks pretty darned horrible.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    EPK Colorist – UP IN THE AIR – nominated for six academy awards
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • Larry Watts
    June 3, 2010 at 4:25 pm
    Aha!
    That was it! I forgot about that setting!
    Did the trick….thanks
    Larry
  • David Roth weiss
    June 4, 2010 at 12:05 am
    Glad that worked for your Larry.
    David Roth Weiss
    Los Angeles
