Activity › Forums › Apple Motion › Canvas missing then crash!
  • Canvas missing then crash!
    Posted by James Rose on October 31, 2012 at 1:54 pm
    D’oh I’ve been working in Motion for the last few days, and upon last launch (after a break) the canvas has gone, I can get access to a few menus but if I poke about too much Motion crashes, I’ve tried deleting the plist file from my library/prefs to reset user settings but no luck, also tried just using one display rather than my usual two to see if it would trick it to reset, I’m now at a lost other than a redownload.
    I’ve attached the crash log if anyone can point me in a direction that would be amazing!
    Link to crash report
    James Rose replied 13 years, 10 months ago 2 Members · 4 Replies
  • James Rose
    October 31, 2012 at 2:44 pm
    Ok solved it by deleting the contents of:
    /Users/james/Library/Application Support/Motion/Layouts/
    Warning this worked for me, I can’t give the advise that this will work for everyone.
  • Bear Baker
    November 1, 2012 at 6:47 pm
    I was having the same problem and trashing the layouts worked. Thanks, James.
  • Bear Baker
    November 12, 2012 at 4:57 pm
    While this solution works, I’ve found that I am repeatedly having to perform it running 5.05.
  • James Rose
    November 12, 2012 at 5:00 pm
    You Sir are spot on, I had forgotten that I had updated… Must be another little bug which has slipped through into the current version.
