Activity › Forums › Apple Motion › canvas aspect ratio
  • canvas aspect ratio
    Posted by Jeffrey Kristen on January 26, 2011 at 4:07 pm
    This is the second time I have had an issue with the canvas aspect when opening a new project in Motion 3. I use the 720p60 preset. Set it as my default. Open new project and the canvas is 4 x 3. I have trashed my preferences numerous times. Verified and repaired the permissions on my hard drive. Last time I had this issue, the trashing of the preferences worked. Not now. When I load a HD template, the canvass is
    the right aspect. Any help on this issue would be appreciated.
    Peter Wiggins replied 15 years, 7 months ago 3 Members · 5 Replies
  • Peter Wiggins
    January 27, 2011 at 12:55 pm
    Have you got “Correct for Aspect ratio” togg;led on in the view menu.
    I dont use 720, but you might like to go back into the presets to make sure all the settings are correct, then set that as the default.
    Peter
  • Jeff Greenberg
    January 28, 2011 at 2:58 pm
    If you’re using the DVCProHD 720 preset, it’s actually 960×720 and will look closer to 4:3.
    It sounds like the switch “Correct for Aspect Ratio” isn’t on.
    Best,
    Jeff G
    Apple Master Trainer
    Avid Cert. Instructor DS/MC
    Avid & Color Videos Vasst.com
    Compressor Essentials Lynda.com
  • Peter Wiggins
    January 31, 2011 at 9:40 pm
    Huh, did I not answer that?
  • Jeff Greenberg
    January 31, 2011 at 9:46 pm
    Sorry Peter – I was tired when I posted, all nighter.
    Best,
    Jeff G
  • Peter Wiggins
    January 31, 2011 at 11:53 pm
    Ah, the curse of the all nighter, been there many times. Just remembering what day it is can be a challenge for me.
