Activity › Forums › Boris FX › Can’t view text using 3D Extruded Text
  • Can’t view text using 3D Extruded Text
    Posted by Carlos Miranda on March 31, 2009 at 8:12 pm
    Hello,
    I’m running AE CS3 for OSX 10.4.11 and just downloaded the trial version of BCC AE6. Here’s my problem:
    I drop the 3D extruded text into a new solid layer, the text window pops up, I can edit my text but once I apply, the text (so does the solid layer) vanishes from the comp view. All I get is a Transparent Comp!
    I tried to mess with the settings from both the 3D extruded filter and AE but I can’t get to view my text.
    Does anyone knows what’s going on?
    Thanks a lot!
    Peter Mcauley replied 17 years, 6 months ago 2 Members · 1 Reply
  • Peter Mcauley
    April 1, 2009 at 12:46 pm
    I believe the problem is that you are running the filters on a system equipped with Mac OS Tiger (10.4x) which does not support the BCC 6 3D Objects filters. To use these filters on a Mac you should use a system with a MacIntel processor and Mac Leopard OS (10.5x).
    Cheers,
    Peter.
