Activity › Forums › Apple Final Cut Pro Legacy › Can’t use transitions on AVCHD files
  • Can’t use transitions on AVCHD files
    Posted by Melissa Herrera on August 5, 2013 at 11:16 am
    I just did a Log and Transfer of some AVCHD footage on FCP. I’m constantly getting an error message saying I can’t use a transition on the footage because there is not enough footage. The thing is, there is. I’m trying to do a transition between two clips that are at least 1 minute long.
    Any ideas what might be the problem?
    MhC – Studio Sixteen Productions
    Melissa Herrera replied 13 years, 1 month ago 2 Members · 2 Replies
  • Shane Ross
    August 5, 2013 at 5:15 pm
    #1 Transitions “Insufficient Content”
    Shane’s Stock Answer #1: Trying to add a Transition and get the error “Insufficient Content”
    A full 1 second cross fade reaches 15 frames into each clip. So, if you want to change a cut to a cross fade, there has to be at least 15 additional frames of each clip. Say you’re trying to cross fade from one clip into the very first frame of a second clip. FCP cannot ‘create’ 15 more frames of the second clip to do a cross fade. If they’re not there, you’re out of luck.
    What you are running into is that you are marking an out point at the far edges of a clip then adding a cross dissolve, say 30 frames (one second) in duration. Since the dissolve is centered on the cut, it will start 15 frames before the cut, and try to go 15 frames AFTER the cut…which it can’t do. What you need to do is plan how long your dissolve will be and back-time your cut so that it works.
    You need to make sure that your clips have enough media (called ‘handles’) at the beginning of the incoming clip and at the end of the outgoing clip for the transition. For example, if you have a 1 second (30 frame) dissolve, your in and out point need to be at least 15 frames from the edge of the clip.
    Shane
    Little Frog Post
  • Melissa Herrera
    August 6, 2013 at 7:08 am
    Why didn’t I think of that? So easy! Of course! 🙂 Thank you very much.
