Activity › Forums › Apple Final Cut Pro Legacy › Can’t use the motion templates
  • Can’t use the motion templates
    Posted by Ramon Aguilera on August 10, 2009 at 11:18 pm
    Hi guys, I wonder if you guys know what to do in this situation.. I have FCP 6 and initially had the blank motion template problem but after updating this got fixed. Now the problem is that part of the motion template does not show in the Canvas, but it does in the Viewer. Also, when i scroll the scrubber in either the Canvas or Timeline, the template works just fine, it just doesn’t play in RT. When using the Preview it will run slower and dropping a few frames.. Finally, i checked if it would export it as it should be, but no it appears the same way as it does in the Canvas: part of the motion template doesn’t show..
    Does anyone know what to do?
    Ramon Aguilera replied 17 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
