Activity › Forums › Apple Final Cut Pro Legacy › Can’t undo markers in source window in FCP 7?
  • Aaron Fisher-cohen
    July 21, 2010 at 5:08 pm
    I bet it would, seeing as merely dragging the old media into the browser to create a new master clip works as well. When I get a chance I’ll try recapturing from the old master clips to see if that works.
    July 21, 2010 at 6:35 pm
    Actually that will be interesting. Right now it looks as if the issue is with the master clips, not the media files. Like I said, re-dragging in the media files makes them behave correctly. I wonder if using the same master clips with new media files will work as well….
    July 22, 2010 at 3:52 pm
    Ok, found a fix. I thought recapturing footage might not work because the problem seems to be with the master clips, not the media files. So I tried exporting an XML of the entire project, then reimporting that XML into a brand new project and everything is great. Identical project, same media, new master clips, and everything is functioning properly.
Page 2 of 2
