Activity Forums Apple Final Cut Pro Legacy Can’t transcode downloaded material from Vimeo
  • Can’t transcode downloaded material from Vimeo
    Posted by Max Frank on February 4, 2011 at 1:44 pm
    I downloaded some of my own material that I have posted on Vimeo because I wanted to make a DVD of the clip [the masters are on a drive that I don’t have access to].
    But when I download the clip it played fine in QT, but iDVD won’t encode it — and when I try using QT7 or Quicktime or MPEG streamclip to upres to DV, neither program will reconize the file for the export.
    The downloaded file is a .mp4 file and it plays fine in QT, but when I Apple-I to look at the info, it tells me have a zero Data Size [?]
    Maybe that’s why I can’t export or transcode it.
    Am I missing anything? Any work-arounds?
    Thanks in advance,
    Wayne
    Aileekate Brown replied 14 years, 5 months ago 4 Members · 6 Replies
  • Chris Tompkins
    February 4, 2011 at 1:50 pm
    Do you have Compressor? You can convert it.
    Chris Tompkins
    Video Atlanta LLC
  • Max Frank
    February 4, 2011 at 2:17 pm
    That’s just the issue – Compressor plays the file but won’t export it, either.
    W
  • Max Frank
    February 4, 2011 at 2:19 pm
    Interestingly, I CAN export it with Premiere Pro CS5.
    W
  • Jeremy Bird
    February 5, 2011 at 12:08 am
    I’ve had luck in the past with trimming out the very first frame of a Vimeo video before exporting or transcoding. It’s strange but it worked.
  • Max Frank
    February 5, 2011 at 9:12 pm
    Hey Jeremy,
    That’s the secret sauce, thanks!
    Wayne
  • Aileekate Brown
    April 25, 2012 at 8:02 am
    A somewhat weird situation. I think you have downloaded the actual video file since you can play it with QT, but i really cannot underatand why other tools meet failure in playing the video. How about use a vimeo converter to transform the video format, then play it with other media players. Generally, I use Video Download Capture to convert videos, it also can be used to download streaming videos online.
