Activity Forums Maxon Cinema 4D Can’t switch between cameras
  • Can’t switch between cameras
    Posted by David Cabestany on February 26, 2013 at 3:31 pm
    Up until yesterday I was able to switch between cameras in my scene by turning on and off the the little icon in the object manager, today I can’t anymore, I have to go into the Cameras>Navigation menu to change them from there, turning on and off the icons in the object manager does nothing.
    I restarted and repaired permissions to no avail, anyone can tell me if I changed a preference by mistake?
    Thanks.
    David Cabestany replied 13 years, 6 months ago 2 Members · 2 Replies
  • Ashish Gupta
    March 4, 2013 at 8:11 am
    David,
    Try deleting your prefernces folder … that will reset and changes to the preferences u might have done accidentally..
    Before deleting make sure to create a backup of that folder .. So that if its not the culprit you can restore your preferences ..
  • David Cabestany
    March 4, 2013 at 2:36 pm
    I’ll try that, I ended up copying everything to a new document. That worked.
    Thanks Ashish.
