Activity Forums Apple Final Cut Pro Can’t share a project in FCPX
  • Can’t share a project in FCPX
    Posted by Lawrence Gray on August 11, 2013 at 10:31 am
    I’ve just got FCP X.
    I’ve edited some clips on four different timelines. Three will “Share” but one won’t.
    What’s the problem there?
    I’ve tried re-importing but that doesn’t seem to work. How can I get that time line to “share”?
    I’ve just found that some of the clips on the time line do not appear in Finder. And since they’re not there, then it won’t share.
    However I’m trying to re-import them but they’re not turning up anywhere.
    How can I be sure FCP X has imported all the clips before I remove them from the card?
    UPDATE….
    Ah, well I’ve re-imported the clips. I’ve found that one has to click on the specific clip and re-import that. And that the camera icon in the right hand corner of the clip means it hasn’t been imported.
    Well, that’s a lesson learnt!
    Ronny Courtens replied 13 years ago 2 Members · 1 Reply
  • Ronny Courtens
    August 11, 2013 at 6:26 pm
    Welcome to the club, Lawrence. Hope you will enjoy working with FCPX.
    Great to hear you have found the solution to your problem yourself. That’s a good way to learn.
    – Ronny
