Activity › Forums › Adobe Premiere Pro › Can’t set bitrate when encoding QT H.264 using Adobe Media Encoder
  • Can’t set bitrate when encoding QT H.264 using Adobe Media Encoder
    Posted by Jack Kelly on October 10, 2005 at 12:02 am
    I can’t set the bitrate when encoding H.264 (aka MPEG-4 AVC aka MPEG-4 part 10) using Adobe Media Encoder from within Premiere Pro 1.5.1. I have Quick Time 7.0.2 Pro installed.
    Within Media Encoder, there is a slider which claims to set the bitrate. However, changing this slider makes no difference! Adobe Media Encoder stubornly encodes the video at about 20Mbit/sec.
    The only way I can encode H.264 Quick Times is by exporting an uncompressed AVI from Premiere Pro and then importing this into Quick Time 7.0.2 Pro.
    Any ideas?
    Jack
    Jack Kelly
    London
    Dir / Prod / Camera
    Steve Freebairn replied 20 years, 11 months ago 2 Members · 4 Replies
  • Jack Kelly
    October 10, 2005 at 8:15 am
    Incidentally, I’m trying to write a page about putting videos online in the Movie Making Manual wikibook. Please take a look and edit as necessary (it’s only a stub at present).
    Thanks a lot,
    Jack
    Jack Kelly
    London
    Dir / Prod / Camera
  • Steve Freebairn
    October 10, 2005 at 1:49 pm
    I’ve had the same problem in both Premiere and After Effects, I was hoping that it was because I didnt’ have quicktime Pro, but since you have it and it doesn’t work that means that there is something fishy going on. I’ve notice that it only changes the bit rate when you change the export size.
  • Jack Kelly
    October 10, 2005 at 2:34 pm
    Ah, interesting.
    How do you change the “export size”? Is this “export size setting” a usable work-around?
    Many thanks,
    Jack
    Jack Kelly
    London
    Dir / Prod / Camera
  • Steve Freebairn
    October 10, 2005 at 9:13 pm
    In premiere when you look at your transcode settings in the Media encoder, it is under the Video area. Underneath where you choose the video codec settings, you can tell the encoder a frame size.
