Activity › Forums › AJA Video Systems › Can’t send IO Captured Media to Soundtrack Pro from FCP5
  • Can’t send IO Captured Media to Soundtrack Pro from FCP5
    Posted by Devin Crane on August 24, 2005 at 2:00 pm
    Can’t send IO Captured Media to Soundtrack Pro from FCP5. It will only allow me to send it as a multitrack item which won’t work for me since I’m trying to take out the noise. I’m capturing the video and audio through SDI.
    Anybody have any thoughts?
    Lee Berger replied 21 years ago 3 Members · 6 Replies
  • Lee Berger
    August 25, 2005 at 1:01 am
    I just did a test using DVCPro50 footage captured from DVCam using the IO with no problems. Did you choose “Send to Soundtrack Pro Audio File Project?” The other option is Send to Soundtrack Pro for Multitrack Project which may be what you wound up with.
  • Devin Crane
    August 25, 2005 at 3:46 pm
    I’ve been capturing to 8-bit uncompressed, and the send to STPro Audio file is not even available, it’s greyed out. The only one available is the Multitrack option.
  • Lee Berger
    August 25, 2005 at 10:57 pm
    Devin:
    I checked out an 8-bit project and you are correct. The send to audio project file is ghosted. If you unlink the audio and video track, the send to audio project file option becomes available. If you don’t need to see the video you should be able to accomplish your noise removal.
    Lee
  • Devin Crane
    August 30, 2005 at 4:13 pm
    The only problem I’ve encountered with that is the IO doesn’t output when there isn’t any video. Go figure.
    Thanks for the help.
  • Michaelle Stikich
    September 7, 2005 at 12:32 am
    How many tracks of audio per clip do you have? I have found that Soundtrack does not support more than 2 audio tracks. Also, it does not work with merged clips or nests. Is this what you have?
    gir
  • Lee Berger
    September 7, 2005 at 1:48 am
    One or two tracks seems to be it, however I haven’t tried any more.
