Activity Forums Adobe After Effects Can’t select plugin parameter in the Effects Control Panel
  • Can’t select plugin parameter in the Effects Control Panel
    Posted by Bob Root on January 13, 2013 at 12:48 pm
    Hopefully I can describe this well enough that it makes sense.
    It seems likely a system problem but is manifesting itself in AE and affecting CS4, CS5.5 and CS6.
    For starters, I am running osX 10.6.8, 2 x 2.8 GHz Quad-Core Intel Xeon with 14 GB of ram.
    The problem is that I am unable to select (highlight) individual plugin parameters in the Effects Control Panel (ie.- Position XY in Particular or Blurriness in Gaussian Blur). The stopwatch, sliders, parameter value and everything else are selectable and can be modified. I just can’t click and select the text for the parameter. I can select it in the timeline panel however, so I’m using that as a workaround for now.
    I have tried trashing preferences, using a different mouse, connecting the mouse directly to the port on my tower (rather than keyboard port) and restarting my computer… all to no avail.
    If anyone has a solution or idea, I would greatly appreciate your input.
    Bob
    Vishesh Arora replied 13 years, 7 months ago 2 Members · 5 Replies
