Activity Forums Zaxwerks Can’t select object or material tabs in Invig Pro
  • Can’t select object or material tabs in Invig Pro
    Posted by Lars Bunch on November 15, 2006 at 7:08 pm
    When I click on the materials setup window button the window that pops up appears with it’s tab selections UNDERNEATH the AE menu bar along the top of the screen. This means I am unable to select the object or materials tab or do much of anything in the setup window. Since I can’t grab the gray bar at the top of the window, I can’t move it to where I can access the tabs.
    If I save and shut down AE, it will work fine the next time I start the program, but Invigorator Pro (4.08) will do this every time I create a new instance of the effect.
    Is it possible that because I am using two monitors, that the plug in is getting confused? Is it possible to make it less confused without having to chuck my Cintiq in th trash?
    Is there a simple fix for this?
    My system is;
    Dual 2Gig G5 w/ 3 Gig memory
    OS-X 10.4.8
    30″ Apple Cinema Display
    21″ Wacom Cintiq Monitor
    GeForce 6800 GT Graphics Card
    AE 7.0
    Invigorator Pro 4.08 Plugin
    Thank you for any help you can offer,
    Lars
    Lars Bunch replied 19 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
