Activity › Forums › Apple Final Cut Pro › Cant Select Location for Import
  • Cant Select Location for Import
    Posted by Scott Parker on October 20, 2015 at 6:58 pm
    Hello,
    I’ve created a new Library and a new Event in that library. When I try and import footage into that new Event, the option to “leave files in place” is greyed out and I only have an option to import into a different Library’s media folder. Of course, this has never happened before so I have no idea, after restarts and trying to track it down, why this would possibly be.
    Thanks for any assistance.
    Scott Parker replied 10 years, 11 months ago 3 Members · 5 Replies
  • Jeremy Garchow
    October 20, 2015 at 8:20 pm
    It means fcpx wants to rewrap your footage to .mov. What’s the format of your footage?
  • Noah Kadner
    October 20, 2015 at 8:31 pm
    Probably it’s from a media type that requires transcoding and can’t be left untouched.
    Noah
    FCPWORKS – FCPX Workflow
    FCP eXchange – FCPX Workshops
  • Scott Parker
    October 20, 2015 at 9:24 pm
    It’s XAVC-I. I understand that FCPX needs to rewrap the footage, but what I don’t understand is why I am can’t select a different destination for the media.
    Usually, when I’m not Leaving Files in Place I can navigate to where I want them to go, but it’s only giving me the option to import the files into a different Library than the one I want the footage to reside in.
    I have no idea why this is happening now, but it’s certainly frustrating. I have media from different projects whoops Libraries (thanks Apple, for that) mixed up in different places now.
    Anyhoo thanks for the comments if I come up with some solution I’ll post it here.
    Scott
  • Jeremy Garchow
    October 20, 2015 at 10:04 pm
    The destination is chosen in the Library prefs.
    Or, you could simply drag and drop the MXF files in to FCPX and leave the files where they are.
  • Scott Parker
    October 22, 2015 at 1:49 pm
    YES Jeremy Garchow!
    Precisely where my ignorance lay thanks for that info!
