Activity Forums VEGAS Pro Can’t seem to render
  • Can’t seem to render
    Posted by Steve Edwards on December 7, 2005 at 5:09 am
    I just did a project with just stills. I compliled at total on the timeline of 2:03.27 hours long. I tried to render this as both mpeg2, and avi, and it showed several pictures from the middle of the project on the preview screen while it was rendering (which took about 7 seconds) and that was it. When I go to the file it rendered, the file plays just those 3 pictures from the middle of the project, and that is it. It is 3 seconds long. What could be causing this? This is the first time that I have done this long of a project and not sure what could be the problem.
    Edward Troxel replied 20 years, 9 months ago 3 Members · 6 Replies
  • Gary Kleiner
    December 7, 2005 at 5:52 am
    Do you have the ‘Render Loop Region Only’ box checked?
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Steve Edwards
    December 8, 2005 at 6:51 am
    Thanks Gary, I figured out what it was. There was a small area set as a region. I seen it earlier but didn’t know how to delete it. Still don’t. I just ended up streching the region all the way to the left, and all the way to the right.
    Also, can you tell me, I am putting in a 16x burner (as soon as I find a good one), and was wanting to know if I could put my 16x as my master at the end of the cable, and take my cd-rom out (which is now slave on the same cable)and put my 8x burner in place of the cd-rom, as the slave on that same cable. I have an AMD XP-3000+ 2.17ghz ,w/1.75mb ram.
  • Edward Troxel
    December 8, 2005 at 2:22 pm
    [steveandbelinda] “I saw it earlier but didn’t know how to delete it.”
    Go to Options – Preferences on the Editing tab and check the “Collapse Loop Region” option. After doing that, clicking anywhere on the timeline will remove the loop region. Clicking and dragging on the timeline will still create a loop region, though. I consider it the best of both worlds and leave this option on.
    [steveandbelinda] “I am putting in a 16x burner (as soon as I find a good one), and was wanting to know if I could put my 16x as my master at the end of the cable, and take my cd-rom out (which is now slave on the same cable)and put my 8x burner in place of the cd-rom, as the slave on that same cable.”
    You should be able to do that.
    Edward Troxel
    JETDV Scripts
  • Steve Edwards
    December 8, 2005 at 3:50 pm
    Don’t see “Render Loop region only”. I am in Options-preferences-editing.
    I do see “Enable looping on events” which is checked, and “Collapse loop region” which is not checked.
  • Steve Edwards
    December 8, 2005 at 3:52 pm
    I do see “Enable looping on events” which is checked, and “Collapse loop region” which is not checked. Yes! I just found it . Yes “Render loop region only” is checked.
  • Edward Troxel
    December 8, 2005 at 4:26 pm
    The “Loop Region Only” option is on the File – Render As dialog.
    Edward Troxel
    JETDV Scripts
