Activity › Forums › Adobe After Effects › Can’t seem to figure out how to apply 2 animation presents to a single text layer.
  • Can’t seem to figure out how to apply 2 animation presents to a single text layer.
    Posted by Paloma Mcclain on February 24, 2018 at 7:34 pm
    Hi all, I use AA CC.
    On a single text layer, I apply the “Florescent light” animation preset from the lights & optical folder. This lasts the full duration. Later down the timeline, I place my Current Time Indicator where I want my second animation, “Explosion 2” from the miscellaneous folder. After I apply this, it takes away the Florescent light effect. Is there a way to be able to keep both?
    Thanks.
    Roland R. kahlenberg replied 8 years, 7 months ago 3 Members · 5 Replies
  • Roland R. kahlenberg
    February 24, 2018 at 10:40 pm
    You’ve got the answer in the other forum.
    If you’ve not read it and for the benefit of others, the issue arises because the Fluorescent Light effect uses a Wiggly Selector. And this should be placed at the bottom of the text layer’s stack of Animator Properties. Explosion 2 comes with three Animator Groups while Fluorescent Light comes with one. Just set up the stacking as prescribed and you should be fine.
    Of course, ensure you place the CTI at its proper place in time prior to applying each preset.
    TypeGEMs – the Definitive Type Gizmo for AE
    https://broadcastgems.com/typegems/
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Adobe After Effects CC ACE/ACI
    Imagineer Systems (mocha) Certified Instructor
    https://www.broadcastgems.com/mographintensity_shapestext/
  • Paloma Mcclain
    February 25, 2018 at 6:36 am
    Thanks for taking the time to help me and reply to both posts!
  • Richard Garabedain
    February 26, 2018 at 4:09 pm
    You might be in the wrong program. There is No flourescent lighting effects for text
  • Paloma Mcclain
    February 26, 2018 at 4:17 pm
    Adobe After Effects. It’s in the Light & Optical folder.
    February 26, 2018 at 10:06 pm
    It’s a type issue – spelling should be fluorescent.
    Cheers
    – RolandK
    PathSlicer – Advanced AE Shape Layer Effect
    https://broadcastgems.com/pathSlicer
    BorisFX mocha Certified Instructor
