Activity Forums Apple Final Cut Pro Legacy Can’t see video when try to digitize
  • Can’t see video when try to digitize
    Posted by Paul Bronsteader on July 24, 2006 at 9:44 pm
    I am trying to digitize DV via firewire and I cannot seem to get the video to show up on my log and capture screen. The screen tells me that the VTR is OK and I see the timecode running in the TC window, but no video. I have restarted and thought maybe it was because my AJA I/O was hooked up, but I turned that off and am still having the problem. I have checked the firewire port and it is working, so I am guessing it may be a setting. I just upgraded to FCP 5.1.1, so I was wondering if that has anything to do with it. Any ideas or suggestions?
    Thanks.
    Paul Bronsteader replied 20 years, 2 months ago 4 Members · 5 Replies
  • 13 Create COW Profile Image
    13
    July 24, 2006 at 9:46 pm
    Have you tried a different firewire cable, it could be a bad cable
  • Paul Bronsteader
    July 24, 2006 at 10:03 pm
    I have tried a new cable and different DV decks. Still the same problem.
  • Bouncing Account needs new email address
    July 24, 2006 at 10:20 pm
    [Paul Bronsteader] “I just upgraded to FCP 5.1.1, so I was wondering if that has anything to do with it.”
    OH yes…
    Try looking here:
    https://docs.info.apple.com/article.html?artnum=301852
    This seems to be the answer to many of these kind of problems.
    AND…
    You should not have TWO FW video devices connected at the same time.
    i.e. A DV camcorder directly into a FW port AND the io unit on and connected to a FW port.
  • Kevin Monahan
    July 24, 2006 at 10:22 pm
    Let’s get the bonehead stuff outta the way first:
    Can you see video in the external monitor?
    Are your A/V presets set to DV NTSC?
    Is your View menu set to External Video > All Frames?
    Have you upgraded anything lately, especially OS X or QT?
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
    Pres. SF Cutters
  • Paul Bronsteader
    July 25, 2006 at 2:35 am
    Matte–
    The Quicktime did the trick. Thanks for the tip.
    Paul
