Activity Forums Maxon Cinema 4D Can’t see vertices/points? Beginner.
  • Can’t see vertices/points? Beginner.
    Posted by Caroline Quinn on March 20, 2014 at 2:28 am
    I can’t see the vertices on my model. I am a beginner. I tried select>unhide all, and making my ‘point handle size’ larger. Both didn’t work. Does someone know how to show vertices in cinema 4d?
    Brian Jones replied 12 years, 5 months ago 3 Members · 2 Replies
  • Nicola Gastaldi
    March 20, 2014 at 2:25 pm
    Select the object you want to see the vertexes.
    Click on the left panel the box with the two highlighted points (the 4th button from the top in R15), and you’re done.
    gasta
    https://www.gasta.org
  • Brian Jones
    March 20, 2014 at 2:26 pm
    you can’t hide them usually but you do need to have an editable object (or a parametric object with a Correction deformer) and be in Points mode
