Activity Forums Adobe After Effects Can’t see Motion Paths?! (with display option selected)
  • Can’t see Motion Paths?! (with display option selected)
    Posted by Ben Hartley on January 28, 2015 at 11:50 am
    I can’t see motion paths even though I have them selected in Display settings. I found someone else who stated turning off time stretch solves this but this has not solved the problem either. Opening project in either CS6 or CC has same issue.
    In desperate need to solve this. Any suggestions?!
    If it looks good, look at it.
    Daniel Barham replied 11 years, 4 months ago 4 Members · 9 Replies
  • 9 Replies
  • Ben Hartley
    January 28, 2015 at 6:52 pm
    I do indeed. Very annoying problem.
  • Todd Kopriva
    January 28, 2015 at 7:37 pm
    Do you have Show Layer Controls enabled?
    After Effects product manager and curmudgeon
    After Effects team blog
  • Ben Hartley
    January 29, 2015 at 11:47 am
    @ Todd – Yes I have Show Layer Controls selected.
    @ Dave – I am using AE CS6 with Mac OSX 10.9.5
    – Ive opened up the project file WITHOUT motion paths showing within a completely differect project that DOES have a comp with motion paths showing, im not sure what this says? Its something wrong with the comp or project and not AE?
  • Ben Hartley
    January 29, 2015 at 3:05 pm
    I believe it may be something to do with this PSD file im using as my BG as I inserted it into a project with motion paths working and it shows as invisible, any suggestions?
    8469_babybelbg.psd.zip
  • Ben Hartley
    February 2, 2015 at 3:28 pm
    Sure see attached AE project file with just the null I need to show motion path with.
    And yes I definitely have Show Layer Controls enabled.
    8483_nomotionpath.aep.zip
  • Ben Hartley
    February 26, 2015 at 12:49 pm
    Any ideas on this?
  • Ben Hartley
    April 13, 2015 at 4:36 pm
    PLEASE could anyone help me with this it really is an issue for my workflow, any help much appreciated!
    Ive even tried installing CC and still no motion paths with the setting selected on ALL KEYFRAMES in preferences.
  • Stephen Mendenhall
    April 24, 2015 at 6:57 pm
    Go to view>view options
    Try turning it on from there. Let me know if this works out for you.
  • Daniel Barham
    May 6, 2015 at 3:09 am
    try Ctrl+Shift+H
