Activity Forums Adobe After Effects can’t see handles when using pen tool when creating masks
  • can’t see handles when using pen tool when creating masks
    Posted by Goldagirl on May 22, 2006 at 9:50 pm
    Hello
    I am creating a mask using the pen tool and I can’t see the handles when I want to use the convert vertex tool. But when I use a rectangular mask or oval I can see the handles. I have had this problem before and I did some how fix it but I can’t remember. I did check the view options and handles is checked correctly. Would love any suggestions. Thank you!
    Jeffrey Parsons replied 15 years, 8 months ago 3 Members · 2 Replies
  • Mike Clasby
    May 22, 2006 at 10:36 pm
    When creating a mask with the pen Tool, if you just hover over one of the previously created vertices you get the Convert Vertex Tool.
    With the selection Tool (V):
    If all the verticies are bold (a little bigger) you can’t see the handles (like when mask shape is selected, the whole mask is selected), so click off to the side, then the verticies (little squares) get smaller and if you click on one of them you get the handles for that one and the ones before and after.
    There might be a better way, but it works for me.
    Oh, I just tried it using the Convert Vertex Tool and it works the same way, you need to select the vertex, not the whole mask.
    You can cycle through the Pen Tools with G.
  • Jeffrey Parsons
    January 18, 2011 at 6:48 pm
    Also check that Roto bezier is off. Right click on the mask, then select “Mask and Shape Path” to uncheck Roto Bezier.
