Activity › Forums › Apple Final Cut Pro Legacy › can’t see firewire
  • can’t see firewire
    Posted by Gregg on August 11, 2006 at 9:11 pm
    We have just installed a firewire output in a Panasonic 1200A and tried to capture 720P through it. We have machine control, but the capture stops with a NO VIDEO error message.
    Dual G5 2.7Ghz
    Huge 4Tb drive array
    Blackmagic design Decklink HD
    FCP Studio 5.4
    OSX 10.7
    How do I check if it’s a Panasonic output or FCP input problem? Don’t have any other decks.
    Thaxter Clavemarlton replied 20 years, 1 month ago 3 Members · 2 Replies
  • Walter Biscardi
    August 11, 2006 at 9:20 pm
    Are you running an Easy Setup of DVCPro HD 720/60?
    Did you turn on the deck before launching FCP? If not, quit FCP and try again.
    Do you see video when you launch L&C?
    Did you go into your menus and ensure that the Firewire output is being recognized by the deck and it’s sending out HD, not SD downcovert?
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Thaxter Clavemarlton
    [Gregg] “Don’t have any other decks.”
    Use a camcorder.
    ANY dv camcorder (even home video).
    Try connecting the Panny to the other camcorder directly and see if its image shows up.
