Activity Forums Apple Final Cut Pro Legacy Can’t see firewire deck after Intensity installation
  • Can’t see firewire deck after Intensity installation
    Posted by Kenny Powerass on August 25, 2007 at 8:21 pm
    I just installed a Blackmagic Intensity PCIe card and now FCP no longer sees my Sony DSR-11 firewire deck. Can I not use both? I only want the Intensity card for monitoring HDV footage. I still need to capture SD DV/DVCAM footage from my deck.
    It’s probably unrelated, but DVDSP also claims to not recognize my blank DVDs. I just upgraded my OS to 10.4.10 and my Pro Application Support to 4.0.1 from 4.0. I’m going to post this issue in the DVDSP forum, but I thought I’d throw it in here on the off chance it is related.
    My system: Mac Pro, OS 10.4.10 (although it was 10.4.9 when I installed the card), 4 GB memory, FCP 5.1.4, Intensity driver 6.2
    Kevin
    Kenny Powerass replied 19 years ago 1 Member · 1 Reply
  • Kenny Powerass
    August 26, 2007 at 11:00 am
    I have no idea why, but the issue mysteriously resolved itself.
    The only thing I can think of that may have had an effect on it is that I unplugged the HDMI cable from the Intensity card and plugged it back in hours later. During that unplugged time I only used the computer for scanning some pictures. My scanning program (EPSON Scan) quit saying it couldn’t find the scanner. I re-opened the program and it found the scanner and worked fine.
    Later, on a whim, I checked to see if I could choose my deck in the audio/video settings pane and there it was.
    PS. I haven’t investigated the DVDSP issue much further, but I did find out that my problem is limited to dual-layer discs only. I was able to burn a single-layer DVD with no problem.
