Activity Forums Adobe Premiere Pro Can’t see export queue window anymore
  • Can’t see export queue window anymore
    Posted by Tim Mccarthy on June 20, 2013 at 2:55 pm
    Whenever I try to export via the queue, it no longer pops up. The only way it’s working now is straight export. Not a huge deal, but when I have more than one sequence, it helps to line them up. Thanks.
    Tim Mccarthy replied 13 years, 3 months ago 2 Members · 2 Replies
  • Kris Merkel
    June 20, 2013 at 4:07 pm
    Works fine here with the same workflow I always use.
    Choose export from the menu adjust your presets and then press the Queue button at the bottom of the Export Settings window. It will then open AME and you can run your batch from there.
    “Think of everything in terms of building capacity.”
    Kris Merkel
    twitter: @kris_merkel
    Product Manager, Flanders Scientific Inc.
    http://www.shopfsi.com
    Co-Founder, Atlanta Cutters Post Production User Group
    http://www.atlantacutters.com
    2.2Ghz MBP core i7
    16Gb RAM
    CS6/FCP7
    AJA T-Tap
    AJA IO XT
    FSI LM-2461W/CM-170W
  • Tim Mccarthy
    June 20, 2013 at 4:16 pm
    Sorry, I didn’t explain my problem clearly enough. I get to the Export Settings window as normal, but when I press the Queue button, AME doesn’t open. It did as of last week. Sorry for not explaining this properly the first time.
