Activity Forums Apple Final Cut Pro Legacy Can’t see Drop out
  • Can’t see Drop out
    Posted by Mervyn on March 13, 2006 at 2:15 am
    Recently while cutting a show, i realise some dropout in the clips. I went frame by frame to find the drop out as i can use digital heaven to take out the drop out. However, i couldn’t find it frame by frame. I had to play and mark and corner off the drop out. Can someone pls help me, is it my setting or is there something i can do to find the drop out frame by frame???
    Cheers
    mervyn
    Martin Baker replied 20 years, 6 months ago 4 Members · 4 Replies
  • Shane Ross
    March 13, 2006 at 4:55 am
    Are you seeing this dropout on the computer monitor, or attached NTSC/PAL Monitor? You cannot judge the quality of the image, or scrutinize if for dropouts on the computer monitor. If they happen on the External Monitor then it is an issue. If it happens on your computer then it is the usual lessening of quality that occurs so that you can see all the frames:
    #2 Playback is blurry
    Shane’s Stock Answer #2:
    ONLY JUDGE THE QUALITY OF YOUR MATERIAL ON AN EXTERNAL NTSC MONITOR, OR AT LEAST A TV.
    1. Disable overlays on the canvas
    2. Make sure you’ve rendered everything (no green bars at the top of the timeline
    https://docs.info.apple.com/article.html?artnum=24787
    DV footage requires large amounts of data and many computations. In order to maintain frame rate and be viewable at a normal size, only about one-fourth of the DV data is used in displaying the movie to the screen. However, the DV footage is still at full quality, and is best viewed thru a TV or NTSC monitor routed thru your camera or deck.
    Don’t forget, the viewer is a viewer, it shows you what you have. The canvas is also a viewer AT THE RESOLUTION YOU SET.
    Shane
    Alokut Productions
    http://www.lfhd.net
  • Peter Wiggins
    March 13, 2006 at 5:30 am
    If the dropout was on field 2 only, you will never see it on an LCD monitor running FCP.
    Again another reason for following Shane’s advice
    Peter
    Free Motion Templates
    https://www.peterwiggins.com
  • Mervyn
    March 13, 2006 at 7:30 am
    Yes, i am seeing on my external monitor. Thats what i usually do when i am watching my playback. So now that i clarify this, how can i get to the the drop out on that frame. I cannot use any other clip as i am doing soccer prog and there is only one take.
    Pls advice
    cheers
    mervyn
  • Martin Baker
    March 13, 2006 at 9:52 am
    The trick is to set your canvas zoom to 100% or greater so you see both fields.
    Martin
    Digital Heaven, London UK
    ________________________________________
    AutoMotion – 0-60 graphics in 5.2 seconds – Now Shipping
