can’t see camcorder
I’ve encountered this problem before and can’t remember the solution… I have an external hard drive connected to my G5, editing on FCP HD. When I connect a camcorder via firewire, then try to log and capture, the system stays on the search mode, telling me it can’t find the camcorder. When I disconnect the hard drive, then the camcorder is immediately found. Someone once told me the G5 needed another video card (or something like that) so that it could detect both the hard drive and camcorder. Does this make sense? I would appreciate an explanation so I’ll know exactly what I need to go get to avoid this problem. Thanks.
David
david.vanhooser@mac.com
