Activity Forums Boris FX Particle Illusion can’t see all layers
  • can’t see all layers
    Posted by Stuart Fellows on July 18, 2007 at 9:00 pm
    I have two layers (layer 0 and layer 1). 1 emitter on one layer, another (different) emitter on second layer. Yet I can’t see both emitters / layers at the same time.
    Is there an option for turning on all layers or something ?
    TIA
    Stuart
    Kirk Tabalotny replied 18 years, 11 months ago 4 Members · 3 Replies
  • Elvis Deane
    July 20, 2007 at 5:17 am
    Check to make sure nothing is turned off in the Layers window. Unless you have the emitters or particles hidden on a layer (either by turning them off in the Layers window or by clicking the star icon beside the emitter’s name in the Hierarchy window), everything on both layers should be visible.
    Elvis Deane!
    The Apprentice Magician’s Guide to particleIllusion
    Wilbur of Wumbaberry
  • Alan Lorence
    July 20, 2007 at 11:49 am
    Unless you mean that you want to see the emitter symbols and paths on all of the layers at the same time. If that’s what you mean, then r-click (control-click on one-button Mac) in the Layers window and uncheck “current objects only”.
    Alan.
    http://www.wondertouch.com
  • Kirk Tabalotny
    October 7, 2007 at 1:22 pm
    … or your emitters might be placed on your stage at different frames – if the missing one appears when you scrub the time indicator, there’s your problem…
