Activity Forums Boris FX Particle Illusion can’t search particle View
  • can’t search particle View
    Posted by Leigh Young on January 6, 2016 at 5:07 pm
    I just bought and downloaded Particle Illusion 3 today and the particle View it came with won’t search. I type something like “fire” into the search field but the SEARCH button deactivates and hitting return does nothing.
    Leigh Young replied 10 years, 8 months ago 3 Members · 3 Replies
  • Brian Fox
    January 8, 2016 at 9:54 pm
    Hi Leigh!
    You should contact our support department at https://support.genarts.com/ to find out what’s going on.
    Brian
  • Francois Blawat
    January 8, 2016 at 10:03 pm
    Hi Leigh,
    I’m sorry but I do not have a lot of experience with that particular issue. I would contact support@genarts.com to see if they can help you out especially since you just purchased Particle Illusion.
    The only thing I can suggest until Alan or GenArts pops up here, is to make sure that once you Press S for search under ParticleView that you have both the IL3 and IEL/ELC boxes checked.
    Good luck.
    FixitMad
  • Leigh Young
    January 8, 2016 at 11:55 pm
    I restarted Particle View and my computer and I can now search all the particles now. Luckily a simple fix that worked after a try or two.
