Activity Forums Boris FX Cant se Final Effects in Adobe Premiere PRO CS5/5.5
  • Cant se Final Effects in Adobe Premiere PRO CS5/5.5
    Posted by Rai Mydland on October 10, 2011 at 6:33 pm
    I have Final Effects trial version, but before I buy this software I have to know if it work properly. I’ve tried to contact Boris via Email, but they did not answer for some reason…
    When I start up Premiere i cant see the plugin. I have tried to put them everywhere inside Premiere’s folder(plugin).
    Jeremy Ellis replied 14 years, 10 months ago 3 Members · 2 Replies
  • Boris Yamnitsky
    October 11, 2011 at 8:03 am
    Sorry to hear that you got no response. Perhaps email got lost in a spam filter. First, let me say that you should not need to move plugins around your hard drive. The installer does that for you. But be sure that you got correct installer: CS4 and CS3 installer is different from CS5. If all fails call our support at 888-77-BORIS.
    Boris Yamnitsky
    BorisFX
  • Jeremy Ellis
    October 11, 2011 at 4:51 pm
    Hello Rai,
    If you are on a PC, when running the installer try selecting Custom Install rather than Complete Install. This will allow you to make sure that CS5/CS5.5 are selected as the host and also set the installation location if it is incorrect. It should be as follows:
    C:Program Files>Adobe>Common>Plug-ins>>MediaCore
    Thank You
    Jeremy
    Boris Support
