Activity Forums Adobe Premiere Pro Can’t run Premiere Pro 2015CC on my MacPro.
  • Can’t run Premiere Pro 2015CC on my MacPro.
    Posted by Steve Garman on December 31, 2015 at 8:13 pm
    I can’t load and run Premiere Pro 2015CC. My 2012 MacPro 5,1,runs all of the other 2015 programs including After Effects, but after a long time loading, PP totally stops with “loading QuickTime Transmit Bundle.” Then errors out after about 30 seconds with the familiar “Couldn’t find a capable video playback module.” It seems this must have something to do with QuickTime but I don’t know why. I have both QT 7.6 and QT 10.?. I never use the latter but always use the former. And all the 2014 CC apps ran fine. PP2014 still does run fine. I’m running OSX 10.11.2 with a GTX 970 4gb card from MacVidCards.com. I’m just stymied! Any ideas would be appreciated.
    Steve Garman replied 10 years, 8 months ago 1 Member · 1 Reply
  • Steve Garman
    December 31, 2015 at 8:24 pm
    Actually the correct error point is when PP says it’s trying to load this: “loading importer Quicktime bundle.” It makes Quicktime look like the culprit somehow. Couldn’t correct my post so had to correct this way.
